Reply
How can I get devices to automatically connect to my Satellite, rather than the main router?
Brads515
Guide
Does anyone know how to get my devices (on one side of my house) to automatically connect to my Satellite rather than the main router each and every time my internet disconnects/goes down for a second/after a blackout, etc?
Since the main Orbi router turns on first, they all grab onto that signal (if the power goes out, my ISP goes down, modem resets, etc) -- and stay on the MAIN routers signal (not the satellite) unless I manually go in each time and connect them on my own to the satellite....anyone know a way of doing this and making sure that devices close to the Satellite, stay on the Satellite and not the main router?
Thanks in advance!
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: How can I get devices to automatically connect to my Satellite, rather than the main router?
You can try lowering the power on the routers radio from 100% to a lower setting. Found under Advanced tab/Advaced Settings/Wireless settings.
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi CBR752 v4.6.7.7(Gateway Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), RAXE500(v78), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1319 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
