- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How do I get an Orbi CBR750 to work with AT&T BGW-320-505 fiber gateway
- Mark as New
- Bookmark
- Subscribe
- Permalink
The AT&T Network sees the CBR750
But I don't get a wirless transmission and the Cable Modem Router and light stays Magneta
and please I"m not very technical and need step by step instructions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How do I get an Orbi CBR750 to work with AT&T BGW-320-505 fiber gateway
The CBR750 is a cable modem.
Att is fibre. Not cable.
And as far as I'm aware, the CBR750 doesn't have a router only mode.
- Mark as New
- Bookmark
- Subscribe
- Permalink
bgw-32AT&T is replacing the Spectrum service
I thought once I disconnected the Coaxial cable and used the RJ45 cables to connect between the AT&T BGW-320-505 and the Orbi CBR750 there would be pass thru communication. So I need to replace the CBR750 with a non Router version to be operational.
Do you happen to know what master I could use to work with the my current satillites ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
RBR750
- Mark as New
- Bookmark
- Subscribe
- Permalink
The CBR works on Cable ISP services. I don't believe ATT uses cable modems or there services.
Please contact the ISP to see what they support ON there ISP service. An RBK series MESH system will work with the ATT modem though...
