ant
Apr 10, 2021Prodigy
How often do you have to reboot your Orbi due to it acting weird/strange/odd?
I was trying to figure out why my LAN speed (copying files) was so slow (e.g., 11 mB/sec) through my updated Netgear Orbi RBK753S-100NAS (WiFi 6; AX4200; 12/8/2020)'s router via network cables between two over decade old PCs. Reboot fixed it.
A few months ago, my Internet stopped working but rebooting the router fixed it. So weird/odd.
What about the rest of you? Thank you for reading and hopefully answering soon. :)
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
ant wrote:I was trying to figure out why my LAN speed (copying files) was so slow (e.g., 11 mB/sec) through my updated Netgear Orbi RBK753S-100NAS (WiFi 6; AX4200; 12/8/2020)'s router via network cables between two over decade old PCs. Reboot fixed it.
FYI I have the Orbi AX RBR850 system and never reboot it to fix problems for my home computers/phones/IoT devices. http://orbilogin.com/debug.htm says that my Orbi has been up for:
> System Uptime: 17 days 17:27:16
You should keep looking for tactics or settings to make your Orbi system more reliable. It unfortunately requires a bit of investigating and getting details when your device(s) are not behaving properly. Sometimes it has to do with the upstream Internet connection/IP your Orbi has with your Internet providers modem/gateway/router/etc. Double NAT may be complicating matters also.
- antProdigy
After the reboot earlier... Basic Information
Firmware Version: V3.2.16.22_1.4.9
CPU Load: 8.11%
Memory Usage(Used/Total): 438 MB/866 MB
System Uptime: 0 days 02:02:25
Server Information
Router Analytics: PROD
CHP Cloud: PROD
XCloud: PROD
BD Cloud: PROD
Circle Cloud: N/A
Is that good? It seems to already use half of the memory and CPU is almost 10%. :/
ant wrote:After the reboot earlier... Basic Information
CPU Load: 8.11%
Server Information
CHP Cloud: PROD
XCloud: PROD
BD Cloud: PROD
Circle Cloud: N/A
This is what my RBR850 says. Yours stats seem fine.
Firmware Version: V3.2.17.16_1.5.1
CPU Load: 12.80%
Memory Usage(Used/Total): 511 MB/867 MB
System Uptime: 17 days 20:19:09
