Orbi WiFi 7 RBE973
Reply
How to access iMac from outside AC2200 Orbi Micro Router (RBR20) network
HAFrank
I replaced my Apple Extreme Base station in my home with an AC2200 Orbi Micro Router (RBR20) and although it is working fine to connect my home iMac to the internet, I am no longer able to access the hard drive on this iMac from the outside. I have used the Orbi app to set up Port Forwarding to the public IP address of the router and am using 549 and 548 as the external and internal ports, respectively. These are the settings that worked on the Apple Extreme base station, but these settings do not work now. Advice welcome.
Message 1 of 2
ekhalil
Master
Re: How to access iMac from outside AC2200 Orbi Micro Router (RBR20) network
I think your best option with Orbi is to use VPN to reach to Orbi from outside and then connect to the iMac.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 377 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
