Orbi WiFi 7 RBE973
Reply
How to connect 2.4G in my Orbi
sukiechan
Follower
My Orbi allows only single SSID name, login & password, sharing between 2.4G and 5G and I guess it is switching automatically.  How can I know which channel I am using?  Some of my devices support only 2.4G channel, how I can switch to connect 2.4G ?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
rhester72
Virtuoso
Re: How to connect 2.4G in my Orbi
You should be able to tell which you are connected to from what the client devices tell you.  If a device only supports 2.4GHz, that's what it's going to connect to, because that's its only option.
Rodney
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2175 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
