Orbi WiFi 7 RBE973
Reply
How to disable / deactivate Armor on RBR50?
slipsibm
I upgraded my RBR50 router to 2.3.1.32 and then 2.3.1.44. Since the upgrade to 2.3.1.32, I have been experiencing frequent loss of Internet access. Before I downgrade back to 2.2.1.210, I wanted to try and deactivate Armor but can't find an option to do this to see if that is the problem. How do Disable Armor?
Anyone else losing Internet access?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 3
Guru
Re: How to disable / deactivate Armor on RBR50?
I would factory reset and setup from scratch if you haven't already. You can try not enabling Armor at this point, do a back up configuration to file, then give it one more try to see if the reset fixes anything...if not, re-apply the back up config from file.
Message 2 of 3
Chuck_M
Mentor
I would also reboot ALL equipment starting at your modem and work my way down to see if that makes any difference.
Make sure you leave power off for a few minutes and remove any batteries before cranking back up.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1888 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
