Orbi WiFi 7 RBE973
Reply
How to disable or Access Control only LAN ports on Orbi Satalite
tompkinss2
Can anyone tell me if it is possible to disable the LAN ports on a Satalite or even better to enable Access Control block, manual accept connections on Satalite LAN ports?  I have a Satalite that people could plug into and get to my internal network without passwords, vs guest wireless and I want to block them unless I allow the mac connection... if not how do I request a new feature?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 3
gfrey
Apprentice
Re: How to disable or Access Control only LAN ports on Orbi Satalite
Advanced --> Security --> Access Control is your only option then use Block All New Devices
Message 2 of 3
tompkinss2
But that blocks wireless and wired ports, I just want to block wired.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3062 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
