Orbi WiFi 7 RBE973
Reply
How to easily update the firmware to the RBS50?
GHSI
Follower
How to easily update the firmware to the RBS50? Everything posted is confusing.
Model: RBS50Y|High Performance AC3000 Outdoor WiFi Mesh Extender and Add-on Satellite
Message 1 of 2
CrimpOn
Guru
Re: How to easily update the firmware to the RBS50?
This post identifies two different Orbi satellites: RBS50 and RBS50Y (outdoor).
Both can be updated the same way:
  • Download the desired firmware from the Orbi support site:
    https://www.netgear.com/support/
    by entering the model number in the search box, then selecting "Downloads"
  • Unpack the *.img file from the *.zip file
  • Connect to the web site of the satellite using a browser, as in http://<ip of satellite>
    example: if the satellite IP is 192.168.1.4, then browse to http://192.168.1.4
  • Enter the Orbi web admin credentials ("admin" and password)
  • Select the bottom menu item: Firmware Update
  • Browse to the location of the unpacked *.img file
  • After a few minutes, the firmware will be updated and the satellite will restart.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 322 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
