- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to force a device to be connected to router and not satellite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to force a device to be connected to router and not satellite?
this would suggest the signal from the sat is better than the router and the system is doing the right thing , you cant really tell the client which it should connect to
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problem with this is, if the satellite signal is only slightly better than the main router, it will connect to the satellite. Unless you are gaming, this is probaly not a big deal. If you are gaming, and your ping doubles because you are connected to the satellite instead of the main router, your gaming performance actually drops. The amplifi HD does this be connecting automatically to the main router unless the signal drops below a certain threshold. It will then connect to the satellite. I hope and pray that netgear adopts a similar approach to their router software.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@GaryInEdmond wrote:The problem with this is, if the satellite signal is only slightly better than the main router, it will connect to the satellite. Unless you are gaming, this is probaly not a big deal. If you are gaming, and your ping doubles because you are connected to the satellite instead of the main router, your gaming performance actually drops. The amplifi HD does this be connecting automatically to the main router unless the signal drops below a certain threshold. It will then connect to the satellite. I hope and pray that netgear adopts a similar approach to their router software.
Don't assume your ping will double on the satellite. My PS4 is hardwired into my satellite and I get 3ms RTT.
Rodney
- Mark as New
- Bookmark
- Subscribe
- Permalink
In my testing, the ping goes from an average of 10 ms when connected to the main router to 22 ms when connected to the satellite. That's not a huge difference but it's enough that I want to be able to steer my connection to the main router when I know the connection is still very good, though not as strong as the satellite. I would imagine tapping into the satellites ethernet port would reduce the ping considerably but I personally do not have that option.
- Mark as New
- Bookmark
- Subscribe
- Permalink
LOTS of variables here. When measuring ping, ensure that:
- The client issuing the ping/echo request is hardwired into the network - i.e. either the Orbi router or (if in AP mode) the upstream router/switch
- Don't trust an "Internet ping" - you can't control a thing beyond your local network. Measure pings _inside_ the network, and not from a gaming device or the like - use a Windows/Mac/Linux/whatever machine connected as indicated above and use it to manually ping the endpoint device on the other side of the satellite
- In my experience, some devices (nVidia Shield TV, I'm looking at you) perform _horribly_ in terms of latency on a wireless connection and effectively must be hardwired for any sort of gaming experience
The actual latency, as measured between the router and the gateway (which is the added latency to any satellite connection), averages ~3ms on my network, as indicated. It's higher than zero, and there is a bit of unavoidable jitter, so it's not perfect, but well within any tolerances for online gaming.
Rodney
Rodney
