- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
How to increase wifi speed (130 mbs fed to router but 39 mbs max wifi )
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello,
I have upgraded my Internet provider to a 120 mbs feed into my home. I am actually getting 130 mbs at the RBR50 Orbi router. However, the wifi speed in my home reaches only 39 mbs. How can I make it faster?
I have one router (RBR50, firmware version V2.3.5.30) and one satellite (RBS50, firmware version V2.3.4.30)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: How to increase wifi speed (130 mbs fed to router but 39 mbs max wifi )
Be sure both RBR and RBS are using same version of FW.
What wireless devices are you using to speed test with? Be sure the device is connected to the RBR or RBS for testing. Turn OFF the RBS temporarily.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same version of firmware are used on bothe router and satellite (V2.3.5.30)
Modem mfr is Hitron; model CODA-4680
Home is 2000 sq ft ,on two story. (1500 + 500). router and satellite are on 1500 sq ft story and 30 ft appart.
Setting modifications and resulting download speed:
Enabled Beamforming
Enabeld MU-MIMO
changed 2.4 GHz from auto to 01: result 37 Mbs download speed
changed 2.4 GHz from 01 to 06: result 24 Mbs download speed
changed 2.4 GHz from 06 to 11: result 28 Mbs download speed
changed 2.4 GHz from 11 back to auto : result 43 Mbs download speed
I live downtown and there are 5 other wifi network with visible SSID and within range.
So the fastest wifi I can obtain is with 2.4 GHz set to auto. When I first posted this, I had 39 Mbs download speed. The only other change was the Enabled Beamforming and MU-MIMO.
Still, 43 Mbs fom an Orbi which can apparently deliver in the 100's Mbs wifi speed is deceiving. Again, my internet feed to the router is 130 Mbs ! Orbi can only pull 43 Mbs out of the 130 Mbs potential. Deceiving.
Any faster router out there?
Orbi was advertised as rocket speed wifi. It is not performing to that level in my book,
- Mark as New
- Bookmark
- Subscribe
- Permalink
What wireless devices are you using to speed test with? Is it connecting at 2.4Ghz or 5Ghz?
Your ISP modem already has a built in router and wifi:
https://us.hitrontech.com/products/service-providers/coda-4680-cable-modem-router/
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did bridge the modem. That was the first thing that I did.
The Orbi router is connected to it with a Ethernet cable and there is only the Orbi wifi network available for my use.
I did all my test with my ipod, on 2.4 GHz.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The iPod will be limited in this wifi design and support. I presume it maybe where your problem is.
I recommend testing with a different device, like a phone, pad, laptop or PC with wireless capabilities to compare speed results.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I checked with a 5 yr old ipad an obtained 45 mbs.
But then I checked with my laptop and got 128 mbs !!
So it is the output device (ipod, ipad, laptop) that throttles the wifi speed and not the router / satelite combination.Interesting.
- Mark as New
- Bookmark
- Subscribe
- Permalink
iPods are not know for there wifi performances. Pads have better wifi, depends on there design and support. To ensure your seeing good speeds on wifi, always check with a laptop or phone or something that has a good wifi design.
Enjoy.
