Reply
How to reply to old Orbi thread with no 'reply' button?
windbagUK
I came to this forum to find a technical detail (about the Orbi system) before potential purchase.
I found an existing thread:
(Maximum Orbi Reserved LAN IP Addresses, November 2106)
about exactly the detail I seek , but with no actual answer to the query.
I wanted to contribute without raising a new thread.
So I have registered, but having done so, there is no 'reply' button.
Would like to request reply to the existing thread....
Model: RBK53| Orbi Router + 2 Satellites Orbi WiFi System
Message 1 of 7
windbagUK
Re: How to reply to old Orbi thread with no 'reply' button?
No thoughts?
Seems a bad move to have to duplicate an existing thread - is that the way to get an answer?
Message 2 of 7
windbagUK
I'm confused.  I'm informed my own reply "has been accepted as a solution".
Eh?
I'm still seeking an answer!
Message 3 of 7
DarrenM
NETGEAR Moderator
Only 64 entries are allowed on WebGUI.
DarrenM
Message 4 of 7
windbagUK
Why?
Message 5 of 7
windbagUK
And anyway, the thread I linked to only had 4 replies....
Message 6 of 7
tagteam
Virtuoso
It is a matter of time. After a certain amount of time passes, you will find you can no longer edit a post you made.
Similarly, when some specified amount of time passes after the last post in a thread (it appears to be 6-8 months or so), no further replies can be made to the thread.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 622 views
  • 0 kudos
  • 3 in conversation
Announcements
