× We are experiencing login issues for several of our services. We are investigating this as the highest priority and will provide updates at Status.NETGEAR.com.
Reply
How to set a separate SSID for the 5 GHz network on your Orbi
Guru
Re: How to set a separate SSID for the 5 GHz network on your Orbi
Has anyone try this?
https://community.netgear.com/t5/Orbi/Kindle-Paperwhite-not-found-my-Orbi-RBR40/m-p/1712069/highligh...
My Setup (Cable 1Gbps/50Mbps)>CM1200 v2.02.03(LAG Disabled)>RBK853 v3.2.18.1/RBK50 v2.7.2.104(WW)
Additional NG HW: C7800/CM1100/CAX80/CM2000, Orbi CBK40, R7800, R7960P, EX7500/EX7700, XR450(v2.3.2.120) and WNHDE111
Message 351 of 852
ekhalil
Master
I tried this and it does not work to force a device to attach to the 2.4 GHz band, simply because Orbi still broadcasts the 5GHz channel but with a hidden SSID which is the same as the 2.4 GHz SSID and has the same password, so a device that has the SSID and password for the 2.4 GHz network will also be able to attach to the 5 GHz network using the same credentials! Smiley Sad
I tried this with different Apple devices and was always able to connect to the hidden 5 GHz network. It can also depend on the device, so maybe some devices -like Kindle- will choose not to try to connect to a network with hidden SSID, but -for sure- Apple devices as well as many other smart devices will.
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBK50 AC3000, Router Mode, Wired Backhaul / Orbi RBK852 AX6000, Router Mode, Wireless Backhaul | Switches Netgear GS208Time Zone CET (Sweden)
Message 352 of 852
Guru
For Apple devices, if one were to "Forget This Network" then try to have the Apple device try to reconnect. It may connect to the 2.4Ghz radio. It would depend if the Apple device will still use the Hidden 5Ghz channel or not though it would have same PW credentials. Smiley Frustrated
It's an option for some to try I guess. One user mentioned it worked for him for his IoT device.
Message 353 of 852
graxxus
More recent firmware, confimed with V2.3.0.28, additionally requires that the following is changed to allow for separate broadcast names:
config set wla_2nd_ssid="CUSTOM5GNAMEHERE"
Model: RBK40| Orbi AC2200 WiFi System
Message 354 of 852
Crazy-Bubble
Guide
It doesn't work for me on the RBR20 either.
I also reported that the Orbi's management interface runs on HTTP instead of HTTPS as well as command line access is via Telnet. How difficult is it for NetGear to get with the program & properly implement secure access? This is another security breach waiting to happen.
Message 355 of 852
Crazy-Bubble
Guide
I tried the following today on my RBR20:
  1. Updated firmware of both router and satellite to V2.3.0.28.
  2. Enabled telnet & made the following changes:
    config set wla_ssid="my5Ghz"
    config set wla_2nd_ssid="my5Ghz"
    config commit
    config get wl_ssid
    config get wla_ssid
    config get wla_2nd_ssid
    reboot
  3. The 5Ghz network name is not visible to any device & when I went in via telnet to see if the configuration is still there, it shows the single network name which has been defined via the GUI.
To me. it looks like NetGear has decided not to allow command line modification anymore & resets the above parameters to default upon reboot.
Message 356 of 852
Retired_Member
Not applicable
I have the same problem on my SRK60 system since the firmware V2.3.0.0 (automatic) update.
The separate SSIDd for the 5GHz WiFi merges back into a single SSID after each reboot.
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 357 of 852
biga888
Initiate
Hi, here is what I did yo keep my main network merged and use my guest for my home automation. I uploaded to the latest firmware 2.3 etc
telnet in
list all the config settingsd that I can set SSID's and then trial and error to figure out which one was which.
config show | grep ssid
config set wla1_ssid="CHROME-5G"
config set wlg1_ssid="CHROME"
config comit
reboot
Now I get my main network SSID and 2 seperate guest networks.
Cheers
Message 358 of 852
Guru
FYI, for users who are trying to get some 2.4Ghz supporting only devices setup on there Orbi's you don't have to separate the SSIDs. You can however disable the 5Ghz SSID from being seen temporarily by setup devices. Under Advanced Tab/Advanced Settings/Wireless Settings. Take the check mark out of the Enable SSID (5G) box. This will hide 5Ghz SSID support for any 5Ghz supporting setup devices and force them to connect to the 2.4Ghz SSID frequency. This should allow the 2.4Ghz setup software on the mobile device to fully discover the 2.4ghz device and get it setup correctly on Orbi. Once completed, Check mark the Enable SSID (5G) box to put the Orbi back in normal operation.
Message 359 of 852
schumaku
Guru
@FURRYe38  is this a new(ish) control introduced on some recent firmware update?
Message 360 of 852
Guru
Seems like it. @Chuck_M confirmed this for me. I initially saw this on my CBR40. I asked about it but got no response from NG. I was able to disable either SSID. The broadcast was still going however seems to force connections to either frequency that the SSID is not hidden for.
Message 361 of 852
Retired_Member
Not applicable
Just got my Orbi from Costcoand updated FW to 2.3.1.44. I tried all of the telnet stuff first, and just unchecking the Enable SSID Broadcast for the 5GHz broadcast allowed me to set up a wireless clock and thermostat that only use 2.4GHz. Also, I had to chnage te MTU to 1464 so my Fire TV Stick would work (under ADVANCED tab, Setup -> WAN Setup). I also had to change my network to 192.168.x.x since my thermostat (Carrier) wouldn't use the default 10.x.x.x network.
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 362 of 852
Guru
Instead of trying to separate SSIDs, there is a Disable SSID broadcast for each frequency under Advanced Tab/Advanced Settings/Wireless Settings. Thus you can hid either freqency while trying to set up a IoT device.
Message 363 of 852
Sto3
I absolutely love the dignified manner in which you addressed this. I strive daily to acquire such sentiment when it comes to my dealings with others. Thanks!
Model: Dual Band
Message 364 of 852
mikegyver
Tutor
Hi,
Anyone know if upgrading to latest firmware v2.3.1.60 will break this separate SSID functionaliy hack?
Message 365 of 852
filski
Initiate
Did anyone figure out how to do this successfully for the RBR20? I tried the telnet approaches and it didn't end up splitting the SSIDs, but just updating both. I have a laptop that keeps joining 2.4 GHz so I would rather set up a seperate SSID and just force it to the 5 GHz.
Thanks,
Philip
Message 366 of 852
Guru
Try disbling the SSID broadcast for either radio. Under Advanced Tab/Advanced Settings/Wireless Settings
Message 367 of 852
blautens
Hey, thanks for this - it was a GREAT help, and I appreciate your sentiments throughout this thread and agree with you. I wanted to help someone else, perhaps. New to Orbi as of today, I came from having dual Asus RT-AC68Us (one in Access Point mode). In retrospect, probably not the ideal Orbi customer. But I digress.
I not only need separate SSIDs for 2.4 and 5 Ghz, but they have different preshared keys.
So, in the CLI, after examining the output from "config show", I figured out that the command below let me change the preshared key for the new SSID I created:
config set wl_wpa2_psk=YOURPSKHERE
No quotes around the presharedkey, and of course, like SSIDs, it's case sensitive.
FYI, rebooting doesn't blow anything away, still works peachy, and I have the very recent firmware - V2.3.5.30.
Hope this helps someone.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 368 of 852
rtackett68
Thank you so much! My Orbi kept assigning my devices to 2.4, which put me back where I started. You are a life saver! Thank you, thank you, thank you!
Message 369 of 852
Did you ever solve this problem? I have the CBR40 and no mater what I do I end up with "Command not found" same as you.
Message 370 of 852
Guru
Separating the SSID is not supported. However you can disable either radios SSID broadcast to help with getting IoT devices connected.
Message 371 of 852
cmgreenman
Apprentice
@mikegyver,
I've updated my RBK50 (router and sat) to 2.3.5.30 and still have split SSIDs. In addition I added an RBS20 to the mix, updated to 2.3.5.26(latest available) and it's showing the split SSIDs as well. Best part is all I had to was add the RBS20 to the mesh and it automatically grabbed all the right configs and set up the split ssids all on its own. No intervention by me required.
Hope this helps.
Message 372 of 852
JacoBeachCondo
How can you split the Guest Network? I am only able to split the first network. Want to make it possible for guests to login to the 2.4 Guest network to access a SONOS play1 that hides on the 2.4
Message 373 of 852
Solarbuddy
Tutor
I was unable to make that happen either but was ultimately successful by picking up a used Sonos bridge and physically attached it to one of the Orbi remotes.
Message 374 of 852
outbreak187
Hello
Any luck with the RBR20?
The ssid changes with the commands; however, right after reboot they go back to the original.
Even with an additional password change.....
Thanks!
Message 375 of 852
Top Contributors
Announcements
