Orbi WiFi 7 RBE973
Reply
How to set up a USB HARD DRIVE to my Netgear setup(details within).
sandman512
Apprentice
So, just purchased the RBK53S-100NAS system for my house.  I was under the impression there was a USB drive as to set up a shared hard drive.  From what I can tell there is no USB drive thus I cannot set that up.  Anyone here have a work around or advice on how to accomplish this?  Thank you.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
Guru
Re: How to set up a USB HARD DRIVE to my Netgear setup(details within).
USB drives are not supported on Orbi. User have been asking about this for a long time. NG doesn't seem to want to support it. They removed the USB port on v2 Orbi and with Orbi AX, doesn't even come with a USB port.
Your best bet would be to get into a LAN NAS system. Entry two bay NAS isn't too expensive. Once you go NAS, you'll never go back to USB.
Message 2 of 4
sandman512
Apprentice
Thank you.  I appreciate the reply!
Message 3 of 4
Guru
Smiley Wink
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 465 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
