Orbi WiFi 7 RBE973
Reply
I can't connect to the satellite Orbi RBS50
Slink131
Follower
One of my satellite disconnected and will not connect. It will either stay purple or color goes away and still does not connect. I moved it right next to my router and it still won’t connect. The other satellite is connected
Model: RBS50| Orbi AC3000 Tri-band WiFi (Satellite Only)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: I can't connect to the satellite Orbi RBS50
Did you try to factory reset the unit?
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 510 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
