Orbi WiFi 7 RBE973
Reply
I have a new Orbi "50", how can i connect my old "40" satellites?
Spotteddog444
Message 1 of 6
Guru
Re: I have a new Orbi "50", how can i connect my old "40" satellites?
Should work. Speeds will differ between the 40 series and 50 series though.
Message 2 of 6
Spotteddog444
In the app setup it does not recognize the satellite
Message 3 of 6
Guru
What 40 series satellites do you have? RBS##?
Are you able to add the satellites using the Sync button on the router and satellite?
@DarrenM
Message 4 of 6
Spotteddog444
RBS40, I've tried the sync button. They flash white, then solid magenta
Message 5 of 6
Guru
What versions of FW are loaded on the 40 and 50 series units? Should all be the same version...
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1318 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
