Reply
I have two internet connections and want to connect to your NETGEAR ORBI SATELLITE RBR50V2 router
kiranwarang
Follower
  I have two internet connections and want to connect to your  NETGEAR ORBI SATELLITE RBR50V2 router at a time is there any way to connect both
connection connect to your  RBR50V2.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Guru
Re: I have two internet connections and want to connect to your NETGEAR ORBI SATELLITE RBR50V2 rout
Unfortunately no.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 3
Guru
You could always use something like and edge router that supports dual wan/failover and then connect the orbi to that in access point mode.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 202 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
