- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
I installed an ORBI 2200. iPhones and laptop WiFi connects OK. I can’t connect our iPad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Model is RBK43 AC2200
I'm able to connect iPhones and laptop to WiFi. Can’t connect iPad. Error messages are either no internet connection or password incorrect. I didn’t have any problem with our 2 iPhones or laptop; so it shouldn’t be a password problem. Sometimes it will connect for about 3 seconds, then disconnect with the password error popping up.
I’ve repeated system setup twice and rebooted iPad several times. Any suggestions? Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: I installed an ORBI 2200. iPhones and laptop WiFi connects OK. I can’t connect our iPad.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Be sure to forget any prior wifi profiles on the phones.
Have you set up the Orbi system for the same SSID and PW used in your prior wifi router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RDMc wrote:I’ve repeated system setup twice and rebooted iPad several times. Any suggestions? Thank you.
Have you told the iPad to "forget" the WiFi network, then scan for WiFi again? (Maybe an incorrect password is "stuck" in memory somehow?)
