Reply
Highlighted
Tutor
IPERF and Orbi RBK53
I'm doing a few iPerf and I'm getting unexpected result.
When I run the iPerf from my router (Synology RT1900AC) / computer I have a normal result (980Mb/s).
When I run an iPerf from my computer (connected on my router) ----- my router connected to the Orbi on WAN1 and my computer connected to the Orbi with Ethernet I only get around 600Mb/s sometime even less (400...)
That's very unexpectred for a local / ethernet result isnt it?
Also I did other iPerf :
Main Orbi to the Satellite, my computer to ethernet via the sat , I get a very bad 300Mb/s (the satelite been 45Feets away in a straight open line).
When I connected to wifi instead, the link that MacOS report or even the Orbi app is 868Mb/s although the Iperf result is between 180 to 260Mb/s
How come my result is so bad? I have a 1Gbit/s internet connection which is a bit pointless at this stage.
Message 1 of 2
Highlighted
Guru
Re: IPERF and Orbi RBK53
Is the Orbi system operating in Router or AP mode?
What is your results with with out main host router in the mix?
My Setup (Cable 900Mbps/50Mbps)>CAX80>RBK50 v2.7.0.70(AP Mode)
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, RBK853, R7800, R7960P,
EX7500/EX7700, XR450 and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 585 views
  • 0 kudos
  • 2 in conversation
Announcements
