Orbi WiFi 7 RBE973
Reply
IPv6 DHCP-PD Issue in Orbi
larryktlee
Initiate
The problem is as follows:
My ISP is to support native IPv6 (SLAAC) for WAN + DHCP-PD for LAN. I cannot connect the IPv6 through my iPHONE every reboot.
After 1 days, I cannot connect IPv6 site again. From iPhone, there is no IPv6 address obtained. It seems that the DHCP-PD is timeout without renewal.
If I tried to reboot the Orbi again, the IPv6 can be used with new prefix. The same situation haven't been found when I used ASUS-87U previously.
So that I think the problem may be in ISP.
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: IPv6 DHCP-PD Issue in Orbi
Hello Larryktlee
have you checked with the ISP on this yet?
DarrenM
Message 2 of 3
larryktlee
Initiate
Yes, the problem is not from ISP. It is because I tried to use netgear R7000 and netgear 6300v2. There is no DHCP-PD timeout issue.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2640 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
