Orbi WiFi 7 RBE973
Reply
ISP said needed an N router
ldehoyos208
Due to rural area, I am now using Blazing Hog Internet and was told that I needed to get a N type router.  I purchased a Orbi 2200 which I was tod supported N and AC.Does it make a difference and is there a way to switch in between as I am having a hard time utilizing the wifi capability on my new Orbi?
Model: RBS40|Orbi AC2200 Tri-band WiFi Add-on Satellite
Message 1 of 6
Re: ISP said needed an N router
N type is an old wifi standard.
Orbi 2200 isn't a Netgear model number, so it is hard to know where to point  for the details, but a typical "Data sheet" will say something like: "IEEER 802.11a/b/g/n/ac".
See the "n" and "ac" in there?
All newer devices are "backward compatible" with anything you own that needs N type.
But it is hard to see how the wifi standard you use enters the picture for your Internet service provider. How does it deliver the Internet?
Whatever router you buy, you will need a modem to get whatever technology Blazing Hog uses to deliver your Internet.
Searching for Blazing Hog Internet just leads to a page that looks like a scam.
You don't need to switch between them. They happen side by side.
What "hard time" are you having?
Message 2 of 6
ekhalil
Master
802.11n or Wireless N supports a max of 300 Mbps throughput.
Orbi RBR20 or RBR40 (AC2200) -which I believe you’re referring to- supports up to 866 Mbps for 802.11AC fronthaul links and 400 Mbps for 802.11n fronthaul links.
By saying that your ISP specifies 802.11n as a requirement, I understand that the data rates that you get from your ISP will never be more than 300 Mbps, right?
If so then Orbi supports higher throughput that what your ISP requires.
Message 3 of 6
ldehoyos208
Very slow connectivity. When I signed up for the service I was informed their service was 5 times faster than a mobile hotspot.  I attempted to connect to their service and it was so slow that none of my work applications worked.
Message 4 of 6
Guru
What ISP service company are you signed up with?
What wireless devices are you connecting to the Orbi?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 5 of 6
CrimpOn
Guru
Blazing Hog's web site is pretty clear that it IS an LTE hotspot.  What the web site claims is that this is faster than typical old style DSL.  (which I agree)
p.s. I, also, clicked on a "Blazing Hog" link that led to a goofy web site, before find the actual company site.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1353 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
