Cesle's avatar
Cesle
In addition to my cable modem (Netgear CM1100), do I need a router in addition to my orbi for wifi?
I have a new Netgear CM1100 cable modem installed. Discovered it needs a router for wifi. I have a new Orbi RBK22 (Costco, so model # is slightly different). Can the Orbi router provide the wifi access I need? Or do I need a separate router?
  • Cesle wrote:
    In followed the app instructions and here's what I have:
    App says:
    Cables connected
    no internet connection
    I have NG CM1100 cablemodem up and running. Plugged into it:
    LAN 1 yellow ethernet cable to desktop computer>Remove the PC from the LAN port 1 on the modem. Connect the wired PC to the back of the RBR.
    LAN 2 white ethernet cable to Orbi internet port>Remove the cable from LAN port 2 and move to LAN port 1 on the modem.
    Coax from outside cable box
    Power plugged in
    Orbi RBK22 has:
    Power plugged in
    White ethernet cable plugged into yellow internet port
    My computer shows:
    Network (connected)
    ORBI34 (no internet, secured)
    Help!
    The additional LAN ports on the CM1100 modem are for Link Aggregation which Orbi doesn't support. So just use the LAN port 1 on the modem for the cable connection to the RBR. You'll get internet then.
  • michaelkenward's avatar
    michaelkenward
    To avoid any confusion to a "yes" answer to two questions, this is the one that matters.
    Your RBK22 is a router.
    Follow the instructions on connecting it to a modem through the Internet port on the back, and away you go.
    • Cesle's avatar
      Cesle
      App says:
      Cables connected
      Power plugged in
      Orbi RBK22 has:
      Power plugged in
      My computer shows:
      Network (connected)
      Help!
      • FURRYe38's avatar
        App says:
        Cables connected
        Power plugged in
        Orbi RBK22 has:
        Power plugged in
        My computer shows:
        Network (connected)
        Help!
