- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Installation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Installation
Hello,
I'm trying to get a complete uderstanding of how to properly setup my Orbi System. My apologies if this question or scenerio has been answered already. I currently have a Fios Quantum Gateway Modem/Router, Orbi RBR50 (router) and Orbi RBR40 (router). So, i have my Fios Quantum set to Bridge mode with the WIFI "OFF" and i have my RBR50 connected in Router mode and being used as my main WIFI connection. Now im trying to hook up my RBR40 across my house and have it hardwired. Now when connecting it i get confused, do i connect from a LAN port of my RBR50 to the WAN or LAN on my RBR40? Also i know i have to configure the RBR40 to AP mode too correct?
Thank you in advance for any assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
You would be connecting the RBR40 via it's WAN port as you would need to configure it for AP mode. Then it will get an IP address from the RBR50 thats in front of it. The RBR40 can only work in router mode or AP mode. RBRs can't work as satellites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
@FURRYe38is correct. The RBR40 must be connected using its WAN (Yellow) port and be in Access Point (AP) mode. If you want, you can give the RBR40 the same WiFi name (SSID) and password as the RBR50 and devices will connect to one or the other. BUT... and this is a BIG "BUT", the RBR40 will not "mesh" with the RBR50.
Before there were mesh WiFi systems, the way to expand WiFi coverage was to add access points to the base WiFi system. It was up to devices to decide which AP to use and when to disconnect from it and pick another one. So, a portable device like a tablet or phone, might connect to one AP and stubbornly try to keep using it as the signal level fell (and fell, and fell) until eventually it dropped the signal completely. Only then would it look around for an AP. Since you have the RBR40, you can make use of it as long as you are not expecting it to become part of the "Orbi mech system."
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
Yes.
Wireless device mostly pick which signal to connect too.
You can connect any LAN device to the back of the RBR40 while in AP mode and get internet access.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
Hey I'm really sorry. I need some more guidance. How do i disable my Fios Quantum Modem.Router WIFI and put it into Bridge mode to have my ORBI act as my Wireless router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
If this is your FIOS box, the answers should be in this User Guide
https://www.verizon.com/about/sites/default/files/fios-qgr-userguide140925.pdf
Looks like page 38 is where you turn off the WiFi radios.
I scanned the almost 200 pages, and nothing "jumped out" about putting it into "bridge" or "passthru" mode. FIOS may not allow that.
(Maybe call FIOS support and ask them?)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
Ok i put my Orbi RBR50 into AP mode. Is there anyway to connect another RBR50 to it to extend the network range?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Installation
This is a frequent question, and the answer is "yes, sort of." An Orbi mesh system consists of (exactly) one router, plus satellite(s) - some people report having 5 or 6 satellites. An Orbi "router" can never be attached as a satellite. What can be done is connect this Orbi router as an Access Point. Although it can be set up with the same WiFi name and password as the primary Orbi system, it will not be part of the "Orbi mesh network". In other words, it will be the same as attaching a $50 WiFi "extender", except that (as far as I know), this extra Orbi router will have to be wired to the Orbi network, not connected over WiFi.
If you already have a surplus Orbi router and have no other use for it, then adding it as an access point may be useful, but it is certainly not as good as adding an Orbi satellite.
(This is the point where people with more experience than I have point out my errors.)
