Orbi WiFi 7 RBE973
Reply
Installed ORBI RBR20 and now security cameras won't connect
LoriLQ
Follower
Hi  - We have the orbi system working and can log in on all devices except the sequirty camera system will not show the live video and a friend said that I need to change the "cookies" or level on orbi settings  - How do I change the orbi settings to allow ?
thank you
Message 1 of 3
Guru
Re: Installed ORBI RBR20 and now security cameras won't connect
Theres no such cookies or configuration to allow cameras to connect. They will connect or they won't.
What is the mfr and model# of these camera?
Are they 2.4Ghz only supporting cameras?
What security mode are you using on the Orbi? Auto? Try WPA and TPIK temporarily to see if cameras will connect. The try WPA2 and AES only.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 3
CrimpOn
Guru
@LoriLQ wrote:
Hi  - We have the orbi system working and can log in on all devices except the secuirty camera system will not show the live video and a friend said that I need to change the "cookies" or level on orbi settings  - How do I change the orbi settings to allow ?
thank you
Perhaps you could identify which security camera system this is?  Was the WiFi name or password changed when the new Orbi system was installed?  Sometimes, the easiest thing to do is to do a new camera setup.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1570 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
