Orbi WiFi 7 RBE973
Reply
Intermittent name resolution issues
tagyoureit
Hi,
I have 3 Orbi RBx50 models running V2.1.4.10 software.  I get intermittent results when trying to access computers on my local network.  For example, one minute this will work...
> ping mycomputer.local
PING mycomputer.local (11.11.11.171): 56 data bytes
64 bytes from 11.11.11.171: icmp_seq=0 ttl=64 time=17.972 ms
64 bytes from 11.11.11.171: icmp_seq=1 ttl=64 time=15.377 ms
64 bytes from 11.11.11.171: icmp_seq=2 ttl=64 time=9.852 ms
but a minute later, I'll try the same and get...
ping: cannot resolve mycomputer.local: Unknown host
I'm not sure what to try.  I have Xfinity and my LAN is setup for DHCP on 11.11.11.1-.254 subnet.  Any thoughts on why my name resolution might have intermittent issue?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 4
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Intermittent name resolution issues
Message 3 of 4
All Replies
Guru
Message 2 of 4
DarrenM
We have a new beta firmware that you may want to try.
https://community.netgear.com/t5/Orbi/Orbi-firmware-update-v2-1-4-16-availability/m-p/1585461#M32958
DarrenM
Message 3 of 4
tagyoureit
Seems to be working great so far.  I saw the beta firmware, but didn't correlate the issues.  It does appear to be working so far.  Will update this thread if I see any more inconsistencies.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1135 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
