Orbi WiFi 7 RBE973
Reply
Internet Connection Issues
Parknuthouse
Tutor
My Orbi is having internet connection issues after I changed cable modem and ISP. Connections are fine and I tried re-boot and re-install procedures with no luck. Any ideas?
Message 1 of 11
Accepted Solutions
Re: Internet Connection Issues
You have a new network.
Reset the Orbi to factory defaults and set it up from  scratch.
It needs to forget any settings inherited from the old ISP and modem.
Message 9 of 11
All Replies
Retired_Member
Not applicable
tell us more about the mode....before and after....Orbi firmware?
Message 2 of 11
CrimpOn
Guru
Kind of vague. "Issues" can mean:
  • No internet at all
  • Can reach some, but not all web sites
  • Some devices get internet, but others do not
Can you please describe what is happening in more detail?
Message 3 of 11
Parknuthouse
Tutor
My mobile ORBI app shows no internet however the cable modem which also has it’s own network is connected and operational. ORBI router is connected to the cable modem via Ethernet cable.
Message 4 of 11
Parknuthouse
Tutor
What is mode that you are referring to?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 5 of 11
schumaku
Guru
Could be your cable modem provider does require some configuration, beyond of a pure Ethernet with DHCP.
Should you have tested the new modem with a computer first, it's predictable other systems like the Orbi in router mode fail to connect to the Internet, because typical cable ISP allow only one MAC address (one device) connected direct to a modem. Power off Orbi, restart the cable modem, wait a few minutes, then start the Orbi router.
Message 6 of 11
ekhalil
Master
........the cable modem which also has it’s own network is connected and operational. ......
What is the make and model of the cable modem please?
Message 7 of 11
ekhalil
Master
meaning, is Orbi operating in Router or AP Mode?
This can be found in the web GUI under >> ADVANCED >> Advanced >> Router / AP Mode
Message 8 of 11
Message 9 of 11
Parknuthouse
Tutor
Resetting to factory settings and reconfiguring network per operating manual took care of the problem.
Message 10 of 11
That's good. This is such a common issue that it deserves a reference in the manuals.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 3187 views
  • 2 kudos
  • 6 in conversation
Announcements
Orbi WiFi 7
