- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Internet Drops out regularly
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi guys, I recently switched to Orbi (RBK50v2) away from my ISP supplied router. Ever since I switched my internet has not been as reliable as before.
First thing I did.was updating to firmware version V2.5.1.8.
When i check the connection status this is what I get:
Lease Obtained | 0 Days, 0 Hours, 5 Minutes |
Lease Expires | 0 Days, 0 Hours, 3 Minutes |
Lease time looks abnormally short. I called my ISP and they say there is nothing wrong on their end. (I am in Australia using Optus with HFC NBN).
Other thing i have tried is spoofing the mac address of the old router with no luck.
The drop out happens a few times a day and usually waiting 2-3 minutes I am back online. I'm sure its not a wireless drop out as I am still able to access the admin page during the outage.Other than this regular drop out, there isn't any other issues.
Anyone experiencing this or got any ideas?
Thanks in Advance
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Internet Drops out regularly
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Firebrace wrote:
It’s an ARRIS CM8200 cable modem supplied by NBNCo. Only one port to go into the WAN port on the Orbi.
Sure looks like modem only. "Only one port" is no guarantee. (Think DM200.) But the specs are silent on any routering.
Did you reset the router to factory settings after the firmware flash?
New firmware sometimes introduces changes that are not compatible with the old configuration.
So while it isn't guaranteed to fix problems a factory reset is the first thing to try if you have issues with new firmware.
Is it the Internet that goes off, or just the wifi? Do the LEDs over any clues? How about the logs?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@Firebrace wrote:Hi guys, I recently switched to Orbi (RBK50v2) away from my ISP supplied router. Ever since I switched my internet has not been as reliable as before.
Lease Obtained 0 Days, 0 Hours, 5 Minutes Lease Expires 0 Days, 0 Hours, 3 Minutes
Thanks in Advance
