Orbi WiFi 7 RBE973
Reply
Internet Speed Direct Connect to Modem v. Direct Connect to Orbi
BEETCH
Follower
I tested my internet speed directly wired to modem and got to 400Mbps.
Then I connected the modem to the RBR50 and connected the same computer via ethernet and did a speed test and got 100Mbps.
When I run the speed test on the orbi app it's consistently around 100Mbps.
Is there some kind of setting i need to toggle to get the same 400Mbps speed thru a direct connection to Orbi as I do when i directly connect to the modem.
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Guru
Re: Internet Speed Direct Connect to Modem v. Direct Connect to Orbi
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 255 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
