- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Internet access from one device intermittently blocked.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi RBR50 with two RBS50 satelite devices all at firmware version V2.7.3.22.
My webserver (Ubuntu Linux) has a wired connection to the RBR50 and the Orbi has a port forwarding rule to pass inbound https traffic to the server.
This all worked fine until fairly recently when I started to notice that my server was randomly not accessible from the the outside world but would come back an hour or so later. Investigation revealed that when this happens the server is blocked from internet access but is available over the internal network. I'm suspicious that this started happening after the last firmware update as it seemed to coincide with Orbi's Armor starting to periodically report external network attacks on my server which I believe to be a new feature. The attack details are limited it just says it has blocked an exploit attack on the server and provides the IP address of the source. I did wonder if the two events are linked, that perhaps the Orbi is denying the server access to and from the internet as a crude form of defence. Having monitored it for a while I've concluded that this seems unlikely as the two events are not coinciding, for example the last reported attack was 4:56am and my server was inaccessible at around 9:30am and back by 11:00am.
Has anyone else observed this kind of behaviour and resolved it? If you have any advice would be gratefully received.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting to note though I'd hitherto been seeing an occasional error message when using the Orbi App saying a random and somewhat unhelpful 'an error has occurred' this has also stopped happening. Coincidence, your guess is as good as mine but I'm thinking probably not.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Internet access from one device intermittently blocked.
This time, don't enable Armor or Circle.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have not done a factory reset as yet. Before I do that I would like to understand why you are suggesting not reenabling Armor? Given that my Web server is exposed to the Internet disabling router level security is not something I'm comfortable with.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Armor has presented some problems historcally. This would be a troubleshooting step only to see if the problem resolves with it fully disabled after a reset.
Your safe running with out it as there is a firewall running on the RBR.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Port 443 on the Ubuntu server is indeed exposed to the Internet, but:
- No other ports are exposed to the internet through the Orbi.
- Unbuntu has a robust firewall that can be set to reject connection attempts from both the local network and the internet (with exceptions for whatever local machines used to administer the Ubuntu server).
- One hopes this web server is configured to survive typical "attacks on web servers"
I agree with @FURRYe38 that turning off Armor temporarily is a useful step toward diagnosing what is causing the server to go off-line. If the server continues to go off-line and then return when Armor is not running, then Armor would appear not to be causing it. If the problem disappears when Armor is disabled, then it might be time to post a big WTF??? message in the Armor forum.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Those messages about exploit attacks specifically mentioned the internal IP of the web server?
My brief adventure in Port Forwarding demonstrated that very shortly after a port is forwarded through the Orbi, it is discovered and people (or Bots?) begin to hammer on it. I turned on Remote Management (the web version, not the apps Anywhere Access). My Orbi password is so long and complicated that I am confident no one will ever crack it, but I became annoyed that the Orbi log filled up so quickly with rejected logon attempts and turned it off. (I could have quit logging web admin access, but I decided to use OpenVPN for that purpose instead.)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
