- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Internet connection disconnect intermittently for sometimes
- Mark as New
- Bookmark
- Subscribe
- Permalink
My internet connection disconnect intermittently sometimes. It disconnected for 3 sec and will automatically connect to the internet soon. May I know how to fix this problem as it already been a long time since I first use the mesh wifi on April this year.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Internet connection disconnect intermittently for sometimes
- Mark as New
- Bookmark
- Subscribe
- Permalink
@bryanchuah17 wrote:My internet connection disconnect intermittently sometimes. It disconnected for 3 sec and will automatically connect to the internet soon. May I know how to fix this problem as it already been a long time since I first use the mesh wifi on April this year.
Do you have just the one Orbi router or satellites as well? Is it the WIFI disconnecting or your Internet connection? How is your Orbi router connected to your ISP modem/router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have one router with two satellite. WiFi disconnecting intermittent for sometimes. For example, when I’m watching any movies (it can be surfing website too) with any devices, it will cut off the WiFi connection for few seconds and connect back within 10sec.
Who is your ISP and what equipment. (modem, router, ONT), did they provide?
What is the current firmware on your Orbi device?
What device is your Orbi router connected to?
Have you changed the network cable connected from the ISP device to your Orbi router?
Are your satellites wired or wireless?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My current firmware Orbi device is 2.6.2.9.
My device that connected to Orbi router are Apple devices like iPhone and iPad and desktop.
Ques: Have you changed the network cable connected from the ISP device to your Orbi router? Yes, I’m using Orbi given network cable
Are your satellites wired or wireless? Wired with switch but connect router with wireless
