Sawdustmaker
Aug 19, 2020Aspirant
Internet speed problem with ORBI
I have AT&T internet and a mesh system with one main and two satellites. The download speed coming in from ATT&T is over 900, but I have buffering problems with streaming TV service, slow speeds on Mac (around 130 download). I tried turning off the ATT&T gateway wi-fi, but nothing changes. Any suggestions?
Thanks,
Paul
Has a factory reset and setup from scratch been performed since last update?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? If the modem has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
hTry enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M9702- SawdustmakerAspirant
I appreciate the response, but it's a little over my head. I'm not that good with this sort of stuff. I have a friend who is, and is going to come over and use your response to see if he can help me.
Ok, sounds good. Let us know. :smileywink:
