Orbi WiFi 7 RBE973
Reply
Ipv6 icmp filtering FIX
_Bender_
Tutor
How to un-filter ICMP:
1. Setup-->WAN Setup--> Enable "Respond to Ping on Internet Port"
2. Advanced Setup-->IPv6--> Set "IPv6 Filtering" to Open
3. Access debug menu at 192.168.1.1/debug.htm --> Enable "Allow external IPv6 hosts ping internal IPv6 hosts"
ICMP should now be "reachable". Check at --> https://ipv6-test.com/
Edit:
Also add icmp to your windows firewall, i'll add a link to a guide below:
https://www.howtogeek.com/howto/windows-vista/allow-pings-icmp-echo-request-through-your-windows-vis...
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 4
CrimpOn
Guru
Re: Ipv6 icmp filtering FIX
Good information for someone who WANTS internet trolls to hammer away at their Orbi.  "Hey, it responds to Ping. Wonder what else is open?"  Would be interesting to hear what specific need this fulfills.
Message 2 of 4
_Bender_
Tutor
You're right, i thought you had to have it enabled to get icmp to not be filtered. Tried deactivating it, turns out icmp works fine without it.
Message 3 of 4
CrimpOn
Guru
Yes, in the default condition, any device inside the Orbi can ping (ICMP) IP addresses outside the Orbi.  But, no device outside the Orbi can ping the Orbi itself or anything inside it.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2912 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
