- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is Orbi RBR20 Compatible with Chromecast?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have tried to connect Google Chromecast to my RBR20 Orbi. Failed. Worked with Gooble Chromecast support over 2-day period. Failed. Researched Netgear Community knowledge base, and sent email to Netgear support.... Case#42184503 ... awaiting a response. Note: Using the Orbi and Google Home apps on android phone.
Without getting into the minutiae of my circumstances, maybe I should ask if anyone successfully connected Chromecast to Orbi RBR20? If they are not compatible, then it's time to quit. Otherwise, if anyone has been successful, please advise with suggestions/recommendations.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is Orbi RBR20 Compatible with Chromecast?
What do you mean by "Failed"?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
@Monterey_JackG wrote:Have tried to connect Google Chromecast to my RBR20 Orbi. Failed. Worked with Gooble Chromecast support over 2-day period. Failed. Researched Netgear Community knowledge base, and sent email to Netgear support.... Case#42184503 ... awaiting a response. Note: Using the Orbi and Google Home apps on android phone.
