Orbi WiFi 7 RBE973
Reply
Is a modem required to connect ORBI to a Internet provider
peterg09
Follower
I understand that ORBIs do not include modems, but are modems necessary to connect ORBI to the Internet coming into the house?  When is a modem necessary and when is it not required?  If it matters, I will be an Xfinity Internet customer and the ORBI is the RBK753S from Costco.  Thank you.
Model: RBK53|Orbi AC3000 Tri-band WiFi System
Message 1 of 3
Accepted Solutions
CrimpOn
Guru
Re: Is a modem required to connect ORBI to a Internet provider
There must be some device that can be connected to the Orbi WAN (yellow) port to provide a conversion between the Internet Service Provider (ISP) network and the Orbi router.  For cable (coax) systems, it is called a "modem".  If the ISP network is fiber, it often a "fiber Optical Network Terminator (ONT)."
My guess is that Xfinity is a cable system.  Customers have the option of renting a modem from the ISP or purchasing their own from the list of supported cable modems on the ISP support web site.
Hope this helps.
Message 2 of 3
All Replies
CrimpOn
Guru
Hope this helps.
Message 2 of 3
CrimpOn
Guru
Don't want to "beat a dead horse", but (flog away anyway).....
You are probably aware that whether to lease or purchase the modem is a classic economic risk/reward decision:
  • Renting the modem will cost more in the long run than buying your own.
    A Netgear CM1100 DOCSIS 3.1 modem runs from $120 (refurb) to $160 (new) on Amazon.
    At the base Xfinity modem rental rate of $14/month, the break-even time is right around one year.
    BUT... when the modem is leased, Xfinity is 100% responsible for the modem. If it breaks, they have to fix it.
  • Purchasing the modem can save $100's of dollars, as much as $168/year.  Wow!
    BUT... if anything goes wrong with the modem, you get to deal with it. File warranty claims. Buy a replacement and wait for it to arrive.
In a crazy twist of fate, my new deal with Spectrum includes the modem at no charge, possibly because I have telephone service through Spectrum. So I have not had to make this decision (yet).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1166 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
