- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Is the switch used for wired backhaul dedicated for this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all,
Thinking of getting an Orbi RBK23 system but I'd like to set it up with wired backhaul.
Because I've got an older home I dont have ethernet cables running all over so I've gotta work with what I have...
If I use a small switch that connects the Orbi main router with Orbi Satellites for the backhaul connection (star connection). Can I also connect other devices to that switch or can it only be Orbi satellites??
RBK50 vs 23 memory is 4GB vs 256MB, thats a big difference but what would it matter??
(Oh yeah, can I assume the chromecast problems are solved as I dont read a lot on that in the later posts 🙂 )
Thanks!
Dirk
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Is the switch used for wired backhaul dedicated for this?
Yes you can have other devices on the interconnecting switch. Make sure its a NON Managed or NON Smart switch.
You can see differences between models here:
https://www.netgear.com/support/product/orbi.aspx
Look under the specs for each model
