Reply
Issues with Orbi AC3000 losing internet connectivity with ATT Uverse(NVG589)
RBK50_user1
Follower
I have ATT uverse and am trying to run my Orbi AC3000 in router mode behind it and I periodically, at least 2-3 a day lose connectivity to the internet.  The Orbi management page shows no errors in internet connectivity and all devices both wired and wireless have connectivity to the Orbi.  However, I can't get any connectivity to the internet, as an example if I try to ping anything it times out.  I have found in this situation if I go to the Orbi managment page and just run a Test connectivity from the internet tab once it gets about halfway through my internet connectivity comes back up.  Otherwise I have to wait several minutes for this to resolve itself.  I have updated to the latest Firmware on the Orbi.  And yes I know I can put it in AP Mode, but then I lose some of the router functions I bought the Orbi for, specifcally Circle.
Lastly as far as I can tell the NVG589 is setup correctly.  When I first set the Orbi up as a router I had issues with double NAT'ing, but was able to solve that by changing the settings on the Uverse box.  I had a previous Linksys router so I just needed to update the Uverse box with the Orbi MAC address, directions here http://www.dslreports.com/faq/17734.  Everything after that cleared up, except for this loss of connectivty, anyone else experience this and solve it?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
ekhalil
Master
Re: Issues with Orbi AC3000 losing internet connectivity with ATT Uverse(NVG589)
This must be related to the ISP lease time issue that was introduced in recent Orbi updates and is still there in the latest 2.3.5.30.
A tested workaround that I currently have and has solved this issue for me to to reduce the lease renewal time in Orbi as follows:
* From browser go to the router's debug page (http://192.168.1.1/debug.htm). Use your router's IP address or http://orbilogin.com/debug.htm
* Enter admin as user name and your router’s management password
* Tick "Enable Telnet" option
* Use Telnet from a computer attached to Orbi to connect to your Router telnet 192.168.1.1 and enter admin and the same password as above
* Enter the following commands:
* root@RBR50:/# config get wan_lease    — Should give you --> 86400
* root@RBR50:/# config set wan_lease=720
* root@RBR50:/# config commit
My Setup Internet Fiber ONT 250↓/250↑ISP Telenor | Wifi Router Orbi RBR850 + RBS850 + 2x RBS750 + 3xRBS350, Wired/Wireless BH / Orbi RBR50 + 6x RBS50 + RBS40V + RBS50Y, Wired/Wireless BH | Switches NG GS208Time Zone CET (Sweden)
Message 2 of 4
Guru
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
I would try Option #2...
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M | XR1000 (Router Mode) and RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 3 of 4
Could be useful:
2016 Bridge Mode Directions for NVG589 - AT&T Community
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 898 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
