- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Just one sites audio won't stream from Orbi
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi RBR50, streams everything except one site:
https://www.rte.ie/radio/radioplayer/html5/#/rnag
This a web player. It will not play on any device or PC.
It will not play on my iPhone, my iPad nor my personal PC.
All other streaming works, I have most, Amazon, Soundcloud,
Netflix, YouTubeTV, .... all work fine.
The RTE site does stream fine in AT&T LTE and any other wifi I am on.
I have pretty default set up, I don't have a double NAT issue.
Any help would be appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Just one sites audio won't stream from Orbi
