- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Just updated firmware RBR50
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just update firmware on a my RBR50 to 2.5.1.8 and now the wireless keeps dropping... any suggestions?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please give feedback to the questions presented as well:
Under Advanced Tab/Advanced Settings/Wireless Settings
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Just updated firmware RBR50
Is the Orbi system operating in Router or AP mode?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Been using v2.5.1.8 since it came out. System has been stable and solid for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where do I set this? Set 20/40Mhz Coexistence to 40Mhz only
- Mark as New
- Bookmark
- Subscribe
- Permalink
