Reply
Just updated the firmware on my RBR40 and it's dead
raiderbruce
Received and email from Netgear to update the firmware...big mistake.  Now the unit is dead.  RBR40 w/ 3 satellites was purchased in 2019.  Now what?
Message 1 of 5
Guru
Re: Just updated the firmware on my RBR40 and it's dead
How do you know its dead?
Whats the power led on it doing?
It wouldn't be the first time a device was corrupted during a firmware update.
I'd first start by trying to factory reset. Push and hold reset for 7-15 seconds while its powered on.
If that doesn't help, you can always try recovering it using tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 5
raiderbruce
Thanks plemans,
I wasn't very specific in my complaint description.  After the firmware installation, I had no wireless nor pass thru wired to my desktop (zero, none, nada).  I had to bypass the orbi and go directly into my pc in order to have connectivity.  I set up my pc as a hotspot for a couple of days to keep my wife at bay.  I repeately did the hard reset or the orbi and went back through the setup and on the 6th atempt, it appeared to take a different route and said it was updating the firmware.  Now it appears to be working and has a new feature (Armor checking for vulnerabilities).  This is something I did not set up, maybe it's from the new firmare???  Anyway, I'm not much of a software/hardware person.  Just pisses me off a $600 piece of equipment can go on the frits with a firmware update and then the company gives you no way to contact them for support.
Message 3 of 5
olympos1625
NETGEAR Moderator
Hi raiderbruce,
Good day!
Welcome to NETGEAR Community!
First of all, we do apologize for the inconvenience of not getting back to you immediately due to the backlog in the system. We are also sorry to hear about your experience with the router. Please provide us your email address, phone number and preferred callback date and time so we can have our Support team contact you for assistance.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
Message 4 of 5
Guru
Any progress on this?
@raiderbruce wrote:
Thanks plemans,
My Setup Internet Cable 1000↓/50↑ CAX80 Mode Mode | ISP SparkLight | Wifi Router Orbi RBK853 v4.6.7.5(Router Mode), Wired BackhaulSwitches Netgear GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi CBK40, CBR750, RBK953(v6.0.3.68) & XR450(v130), RBK853 v4.6.7.5(AP) & RBK752 v4.6.7.5, RBK50(v23), SXK30(v110), R7000(v34), R7800(v84), R7960P(v84), EX7500/EX7700, GS308v3 and WNHDE111
Testing
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 478 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 6E
