- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Known Issues. Orbi Firmware V 2.1.4.10 update
- Mark as New
- Bookmark
- Subscribe
- Permalink
Known Issue:
This one is published in the release notes for the 2.1.4.10 update
- When user has two or more Orbi satellites connected to Orbi router using Ethernet backhaul connection, an Orbi satellite might not connect to the Orbi router after the firmware update. A workaround solution is to reboot the Orbi router and then wait for 2 –5 minutes.
Orbi Community issues experienced
- Apple Homekit works with Lifx smart bulbs. Under firmware versions 2.1.3.4 and 2.1.4.10, Apple Homekit shows that one or more of my 4 Lifx globes are "unresponsive"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Known Issues. Orbi Firmware V 2.1.4.10 update
There is alredy a HomeKit thread going. I would recommend posting there as it seems very active, regardless of FW version. Would help to keep all of the home kit issues in one place so NG support can review them more easily.
No everyone has problems with mutliple satelites and this version of FW.
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-4-availability/m-p/1558339/highlight/true#M29200
I would recommend reporting issues, known or new in that same thread as well. Lets keep v2.1.4.10 issues posted there, good or bad. Helps keep the information located in one area. That thread is very active as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Per this thread the update to 2.1.4.10 reinstated a previous problem that I had with both wired and WiFi down;oad connection speeds being throttled by the RBR50 Router.
I previously overcame this by a factory reset. I'm really annoyed that it seems that I have to go through set up all over again to get the full connection speed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank god for Best Buys 2 year warranty. I am taking these pieces of crap back. I have had these Orbi RBR/S 50's for almost a year now and Netgear has yet to release a stable firmware. What a F'ing joke and waste of $450. Buying Meraki AP's, will never buy another piece of Netgear Sh1t again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good day,
The 2.1.4.10 update broke my wired backhaul. Everytime I plug in my Satellite to the ethernet backhaul - the Internet goes down. And I must reboot the modem and the Orbi Router. Is there a fix coming soon or can I re-install a previous firmware?
Tracy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has the entire system been powered OFF for 1 minute then power ON after the FW update?
If this fails, try a factory reset on the router and satellites then set up from scratch. Reconnect the satellites via wireless first, then connect the ethernet cable between the router and 1 satelllite and give 5 minutes for the sysem to configure it. Should see BLUE LED on top of the satellite.
Any network switches in between the router and satellite? If so, mfr and model#?
@tschroeder wrote:
Good day,
Tracy
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same issue for me. I have RBR40 router and 3 RBS20 sats in my system. 1 of the sats is connected by ethernet.
I don't know when the firmware auto updated, but I couldn't get an internet connection through wifi after it did. Anything hard wired to the router worked fine. It just wouldn't broadcast internet via wifi. Really maddening.
Spent over an hour with technical support. At that point, I hadn't figured out it was the firmware. They never brought up the firmware as a potential culprit. Did a bunch of troubleshooting. It was crazy. Everytime I restarted the router, internet worked briefly, then cut. In retrospect I now see that the moment internet cut is when the wired sat reconnected!
Anyway, I later realized firmware could be the issue. Rolled back to 2.1.2.18. Very stable version and problem completely resolved.
I have a return call pending from a "level 2" tech support. I am asking how to disable auto update of firmware. If it all works perfectly, I'll stick with this version.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Disney circle will prevent some websites loading now after firmware update.
*****THIS IS NOT CIRCLE FILTERING WEBSITES*******
All filtering has been turned off, still cant load some websites. After I disable Circle, all the problematic websites load fine.
I reset Circle and reestablished it all over again. Problem started again.
Turned off Circle, problem goes away.
******DON'T THINK FOR A SECOND IT IS BECAUSE A WEBSITE WAS BEING FILTERED, I CHECKED ALL THE REPORTS AND THESE PROBLEMATIC WEBSITES ARE NOT BEING FILTERED OUT. ******
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Amazing update! I had just upgraded my cable speed tier, which meant I had just installed a new DOCSIS 3.1 cable modem. Then I went away for the weekend. Got several notifications while gone about disconnected services, but figured I'd relax and it would all come back online. Nope.
Got home and obviously immediately suspected something wasn't playing nice with my new setup. But it was strange -- the Orbi just wouldn't let me reach it at 192.168.1.1. Any attempt to access it, to tftp the firmware, heck, even just ping it, would time out. Odd.
Connectivity sort of worked when I unplugged the Orbi from my wired internal network. Hmm, strange. Wouldn't have expected that.
And then I found this thread. Unplug the satellites from the wired backhaul? But how the heck could that possibly impact my ability to reach the RBR on the netwo ... oh fudge. Really? Really, Netgear? We waited years for this freakin wired backhaul, and then you break it in some incredibly bizarre manner with this automatically installed firmware update.
Fortunately, I'm back online with a somewhat hobbled system that is configured for wired backhaul usage -- with satellites too far apart to reliably connect at 5G. And so it will stay until this gets patched back in correctly.
TL;DR: Netgear stressed me out after a relaxing weekend getaway. Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same issues other have experienced: With 2.1.4.10, ethernet backhaul no longer works, and if I leave the ethernet cable connected to the satellite, the entire network becomes unusuable. Spent hours trying to fix: factory resets, many reboots, as suggested by Netgear support, downgraded to 2.1.3.4 but it auto updated right back to 2.1.4.10 within one hour. And I don't want to rely on an unsupported backdoor-- telneting to disable the autoupdate flag as others have suggested elsewhere, not a way I want a product at this price point to behave. Firmware updates need to be user controlled: option to turn on autoupdates, option to turn off auto updates, option to install, skip or postpone an update. All other good computing related products provide those options. I don't want to be forced to be a beta tester of new firmware. Makes no sense. I am still within the window to return the system so am hoping for a fix soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try this process?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I powered down both units for a long time. Then powered on the router, then the sat, then plugged the backhaul cable back in. Within 30 seconds the entire system lost internet connection. I don't really have time to do a factory reset. I will live with non-wired backhaul for now or downgrade my firmware If I can prevent an auto upgrade.
Netgear Support - When can we expect to see this resolved?
Community - Has anyone found a solution to
#1 - Restore wired backhaul?
#2 - prevent Auto Firmware update?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same problem with the Firmware update - On my desktop Wired through a switch to the Orbi - Cant get to some websites. As soon as I disable circle - Websites come right up.
Netgear - Need a fix for this terrible firmware update
- Mark as New
- Bookmark
- Subscribe
- Permalink
With 2.1.4.10 and circle switched on various sites cannot be resolved (these are not filtered sites). I have been forced to switch Circle off and have thus cancelled my subscription until this is fixed. I must return to using "service blocking" as a parental control and this is very unsatisfactory.
Related point: If Netgear improved the service blocking to allow multiple schedules, which is perfectly feasible and not a big step, then I would not need a circle subscription.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try these?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Homekit issues are known issues. They released a hotfix. See the link below.
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-4-Homekit/m-p/1565698/thread-id/31140
- Mark as New
- Bookmark
- Subscribe
- Permalink
@tschroeder wrote:
Good day,
Tracy
I had the same problem with my RBK20 after updating to 2.1.4.10. I went back to 2.1.2.18 and everything was fine again. Then I found this post and did another try yesterday. Most important is time. I waited 5-10 minutes after each step and now the Orbis are running fine with FW 2.1.4.10 for 12+ hours.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am having the same issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello WimLibby
what issue are you having?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try factory reset and set up from scratch. Disable Daisy Chain. Add 1 satellite via wireless first. After the top LED turns BLUE and goes OFF. Connect the ethernet cable between the router and satellite. Wait 5 minutes. Top LED should turn BLUE.
Any network switches in between the router and satellite? If so, whats the Mfr and model#?
@tschroeder wrote:
Disabled daisychain, restarted, waited, time in between starting each device, Reset all devices. Did not do factory reset. Still back haul does not work. Brings the whole Internet down.
- Mark as New
- Bookmark
- Subscribe
- Permalink
