Orbi WiFi 7 RBE973
Reply
Lag spikes with RBK50
cmeyer1213
Follower
I recently got the RBK50 Orbi setup and I would say I love it except Im getting random lag spikes in most of my games, Ill have low ping and then it will spike anywhere from 100-300. Normally I would say this is a connection issue but I have the desktop hooked up to a network switch to the satellite in my room. So I shouldnt be getting this proble, I also have ATT Gigapower internet so I have very fast service. I want to blame the gateway that they have supplied that I have to use for the tv. Does anyone have advice?
Model: Orbi High-Performance AC3000 Tri-Band WiFi System (RBK50)
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Lag spikes with RBK50
You would have to look at the logs of the gateway for when these spikes happen and see if it the internet or if its the router that is causing the issue. Also you may want to remove the network switch see if that may be causing a issue.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 894 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
