Reply
Laptop stopped detecting Orbi RBK50
Peterwg
Follower
I have several laptops, tablets, TVs, mobile phones etc connected to my Orbi RBK50.
One of the laptops now does not detect the Orbi.  I have had the laptop examined by the local specialist and he has updated Windows 10 and the network card driver.
This laptop connects to other networks and will connect to the Orbi using an Ethernet cable.
Anybody have any potential solutions?
Model: RBK50| Orbi AC3000 High-Performance Tri-Band WiFi System
Message 1 of 2
Guru
Re: Laptop stopped detecting Orbi RBK50
What FW is currently loaded?
Does the LT see the wifi SSID name or just won't connect to it?
Be sure that the IP address is a reserved IP address set ON the router for the Laptop. There many two IPs needed, one for the Wireless connection and one for the wired connection.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Try setting WPA to disable temporarily. Does the LT connect then? If so, go back and test WPA and TPIK and test. Then try WPA2 and AES only.
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)>RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, XR450(v120) and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 596 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
