- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Laptops keep dropping wifi from satellite
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey everyone,
So as of a week ago my macbooks/windows laptops ONLY when connected to my orbi SATELLITE (RBS50) frequently drop wifi connection every 10 seconds or so. This DOES NOT affect iPhones/iPads/other wifi gear, but ONLY laptops. If I connect them to my main router RBR50 there's no issues.
Has anyone experienced this lately? This is super annoying so much so I have just completely unplugged my satellite for now.
Things i've tried:
- Power cycling
- Updated firmware from 2.5.1.8 to latest 2.5.1.16
- Factory reset satellite (RBS50)
- Factory reset main router (RBR50)
- Tried modifying advanced settings per online recommendations and still doesn't work so I just put it back to factory default settings for now.
Thanks everyone!
Brandon
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Laptops keep dropping wifi from satellite
What is the mfr and model# of the laptop and the mfr and model# of the wifi adapter in the laptop.
Sure the wifi adapter drivers are up to date.
If this only happens with the laptops, then they may need more review.
Do they connect at the RBR with the RBS turned OFF?
https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
