- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Latest Firmware V2.5.0.38
- Mark as New
- Bookmark
- Subscribe
- Permalink
I applied this latest firmware and my satellite is no longer connected. Also my attached devices is not working. It seems wonky. I'm not sure how to get my sattelite back nor do I trust what my devices are.
Is there anyway to roll this back? Or is this a known issue?
Thansks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Latest Firmware V2.5.0.38
Was this FW update in the RBRs web page?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No not at all. I update to the lastest firmware since I've installed it, usually without a problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please try a factory reset on the RBR and RBS and setup from scratch. Walk thru the setup wizard.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
First fo a BACKUP of the configuration to file. Then do the factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@FURRYe38 wrote:Has a factory reset and setup from scratch been performed since last FW update?
You didn't answer these questions:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please try a factory reset and setup from scratch first to see if you get the system back up and running. Let us know.
https://community.netgear.com/t5/Orbi/New-Firmware-v2-5-0-38/m-p/1813852/highlight/true#M73266
@RDMSYS wrote:
I always do when it says theres a new firmware. Why shouldn't I?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RDMSYS wrote:
They did push it. That's why I applied it.
2 methods to FW being applied:
1. They make it available - you see it when you login to your router and you make the decision to apply it.
2. They push is auto and you have no control.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well I assumed that if it's available then it's okay to apply. So, I factory reset the router AND the satellite? And then factory reset the satellite? Then re add the satellite and then import the backed up config file?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also, I downloaded the previous version I had. I guess it's a bad idea to manually update it using them?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can no longer rename my devices through web, you make the changes and save, but it will not change
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, factory reset the router and satellite. Walk thru the setup wizard on the RBR and setup the system from scratch.
I'm updating mine as I type this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RDMSYS wrote:Also, I downloaded the previous version I had. I guess it's a bad idea to manually update it using them?
The previous version will take as long as NG is not pushing a later version.
Once your system settles down, leave it alone.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I'll have to wait till after 5:00. Where is the setup wizard again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
So after I get the router and satellite added back in, then I can import the config file?
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, I'm going to try a differernt tact. It seems JUST the satellite is gone. Theres a button to remove it in the ATTACHED DEVICES screen. I'm going to remove it and try to resync it before doing a factory reset.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes you can do that as well. Let us know how it goes.
IF it doesn't worl, please factory reset the RBR and RBS and setup from scratch.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, my RBK50 is setup and running. Use the Update ALL to apply the new version. Factory reset RBS and RBR and setup from scratch.
