- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Limit Connections to an Orbi Satellite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi! I watned to see if there's a way to limit connections to the satellite. In my case, the satellite is off in my den primarily to support an XBox and a computer that I can't physically wire and that are far enough away that performance (without the satellite) is relatively poor. I don't mind other devices from the room (mobile phones, etc) connecting to the main router.
For example, can the satellite be setup to use a different wifi name / password, so all existing devices go through the router except for the devices I select to go through the satellite?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Limit Connections to an Orbi Satellite?
The MESH system is designed and meant for automatic connections based on your location and device support and signals and such using a single SSID name and PW system. Everything is fairly automatic in MESH systems.
