- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Limit device to LAN using RBR50v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am trying to do something with my Orbi system (RBR 50) that may not be possible. (Certainly, I have yet to find a way to achieve it.)
I have a device on my network that does not need to connect to the wider internet. I can see that it is possible to control the device's access to the network, but I think that will shut it off from the LAN as well as the WAN. Is there a way of allowing LAN access but not WAN access?
Thanks,
Mark.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@MarkGould13 wrote:I have a device on my network that does not need to connect to the wider internet. I can see that it is possible to control the device's access to the network, but I think that will shut it off from the LAN as well as the WAN. Is there a way of allowing LAN access but not WAN access?
Have you tried the Orbi web interface, Advanced Tab, Security Menu "Block Services"?
Set up one block for "Any" services, ports 1-65535 on the IP address of that device. and make the Schedule "Always".
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
