- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Limited selection of dyndamic dns services
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there going to be a firmware upgrade for selection of dynamic dns services? There are only 3 available. (no-ip, netgear and dyn). I already subscribe to another dns service for years. If I had known this, I probably would not have bought it. You should be able to enter in whatever DDNS service desired.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ekhalil wrote:
Yes, it's probably the best option to have the router update your DDNS, but you know that you can also use any other device at home (computer, smart phone, smart tablet, any unix-based machine, ...) to update the DDNS with your public IP address, and this way you can use your DDNS address to remotely reach Orbi or any of your home devices.
The only thing where it's mandatory to have DDNS configured in Orbi is for use of VPN towards your home network, and for this you can subscribe to the free Netgear DDNS.
Thanks for the reply. Yes, I can use the computer to update the external IP but it would be nice to have the Orbi do it for me. But it doesn't change very often. I also have VPN so I guess I will be using the Netgear DDNS.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Limited selection of dyndamic dns services
- Mark as New
- Bookmark
- Subscribe
- Permalink
