Orbi WiFi 7 RBE973
Reply
Logitech Squeezebox continues to lose connectivity
Gellie
Just started. Not sure if there was some software update? It stays connected to the 2.4ghz satellite (25 feet away) for several hours, perhaps days. Then disconnects and I need to reboot the Touch. Are there any settings I need to adjust? TIA
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 4
Guru
Re: Logitech Squeezebox continues to lose connectivity
Has a full power OFF of the Orbi system and ISP modem for 1 minute then back on with the modem to let it sync then ON with the Orbi system been performed yet?
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Message 2 of 4
Gellie
Running 2.5.1.8. Tried all channels you mentioned. I have unplugged Fios router, main Orbi and the 3 satellites. No help.
Message 3 of 4
Guru
Is this the only device that seems to have problems? I would make contact with the devices mfr and ask for help and information regarding this.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1709 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
