Orbi WiFi 7 RBE973
Reply
Logs in Administration on displays one hours of log (ORBI RBR50)
Conax
Guide
I'm using Orbi RBR50, and would like to check what sites my children have been onto. But the logs in Administration only shows activities in the last hour. How do I get more than that?
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Logs in Administration on displays one hours of log (ORBI RBR50)
Hello conax
Orbi does not have a in depth feature like that you may have to look for some other software.
DarrenM
Message 2 of 3
Conax
Guide
Thank you  Darren for your reply. This is however quite disappointing, consider this is not a set of cheap devices, and that if it has the capability of writing logs why restricted it to just an hour?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 503 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
