Orbi WiFi 7 RBE973
Reply
Losing Internet
justjib
Follower
Losing Internet
I have an RBR40 Orbi mesh network installed in my home. I recently installed an Arris Cable Router. On a daily basis, I lose internet and when I reset the 'Arris Router' my internet comes back. The Orbi network is connected to my 5g Arris network. I want to change the Orbi network input to 2.4ghz because I now understand this provides greater stabilty, but has less range. How do I change my Orbi cable router input to 2.4ghz?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Guru
Re: Losing Internet
If you have a router built in to the ISP Modem, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Message 2 of 3
Mstrbig
Master
Re: Losing Internet
What ISP service do you have? What Arris Cable router do you have? If rebooting the Arris is solving the issue, there's a good chance the issue is with the Arris. But more information would help determine what is causing the disconnect.
Your statement: "The Orbi network is connected to my 5g Arris network" doesn't make sense, since the Orbi RBR40 router had to be wired connection.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 414 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
