- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Lots of bufferings when watching TiVo recordings or live shows
- Mark as New
- Bookmark
- Subscribe
- Permalink
Here’s my problem: whenever I watch TiVo live shows or recordings from my iPhone XS Max or iPad, there are lots of bufferings, the video keeps pausing. Any idea how to fix it? Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Lots of bufferings when watching TiVo recordings or live shows
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using? Try WPA2 and AES only.
Try enabling the following and see: Beamforming and MIMO.
Disable Fast Roaming and IPv6.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is the first I have heard of a "TiVo modem." The original TiVo boxes came with a dial-up modem to connect to a phone line, but this was before internet access was common. (I believe modern TiVo's no longer include one.)
Could you be more specific about exactly what product the router and satellite are connected to and who your internet provider is?
Your iPhone and iPad are connected to the Orbi and have a strong WiFi signal and you are using the TiVo app?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The distance between RBR50 router & RBS50 satellite is about 15 ft apart.
Currently, daisy-chain topology & IPv6 are disabled. Beamforming, MU-MIMO, fast roaming are enabled.
I’m going to try disable beamforming, MU-MIMO, and fast roaming. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I live in a subdivision, so yes, I’ve neighbors on my left, right, and back.
I’ll try your suggestion to disable beamforming. I’ll also disable UPnP. Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also move your satellite. 15' is pretty close. About twice that or a bit more is optimum without major obstruction.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I forgot to ask which model of TiVo and where it is connected.
I'm also a bit confused about how the Technicolor DPC3848VM modem/router is configured. Google search turned up a reference that when this device is in bridged mode, only a single ethernet port is active. (The modem/router that I have from Spectrum is certainly that way. It has four ethernet ports on the back and when I turned off the router functions, only one ethernet port is active.)
When you look at the Orbi "Attached Devices", where does it say your iPhone/iPad and TiVo are attached (router, satellite, or wired)?
- Mark as New
- Bookmark
- Subscribe
- Permalink
15 feet to TOO close. Please move them farther out as suggested by @JoeCymru
@va3lim wrote:
All channels are currently set to Auto and security method is WPA2-PSK. I don’t think WPA2-AES is available.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I’ve restored the configuration of Technicolor DPC3848VM as modem/router (disconnected the Orbi devices), no more bufferings when streaming videos from TiVo & Plex apps. Thanks all for help. I’m returning the Netgear Orbi AC3000.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@va3lim wrote:
My model of my TiVo modem/router is Technicolor DPC3848VM Docsis 3.0 Gateway. I’ve the Netgear Orbi AC3000, it has a router RBR50 & a satellite RBS50, both of them are connected to the back of DPC3848VM.
I think this is part of the problem - both the RBR50 and RBS50 should not be plugged into the back of the modem. The RBS50, if connected to anything, should be connected to the RBR50, if you want to use ethernet backhaul instead of wireless backhaul.
I agree with everyone else - 15 ft apart is too close - your devices are probably having a hard time deciding which Orbi to connect to as the signals are probably severely overlapping.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Beamforming and MIMO should be enabled as well. Also enable WMM.
This is probably a placement and wireles configuration issue.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your explanation makes sense. Thank you so much. I will order the Netgear Orbi AC3000 again and give it another try with your suggestion (RBS50 will be connected to RBR50 and try to separate them further).
- Mark as New
- Bookmark
- Subscribe
- Permalink
WMM is already enabled. Beamforming and MIMO were enabled previously but I disabled them due to someone's suggestion. Those 2 features don't make any difference when viewing streaming movies from TiVo and Plex, I still experience bufferings. Best Buy technician thinks I could have a bad Orbi and recommended me to replace it at the store.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, possible the Orbi unit you have is faulty. Let us know if you get a replacement and how it turns out.
This users Orbi does work for him:
https://community.netgear.com/t5/Orbi/Buffering-video-when-streaming-from-NAS/m-p/1677895#M47628
- Mark as New
- Bookmark
- Subscribe
- Permalink
Separate them as far as you can, even if the separation seems forced, like putting them right next to outer walls on opposite sides of your home. Try to get that minimum distance of 30 feet, but it's OK to have 50-70 feet between them as well. Think about it in terms of a bubble surrounding each device representing the wifi signal. If those bubbles overlap too much, you create a problem The ideal distance is the one that supports the highest speed connection between the devices while minimizing the bubble overlap. They have to overlap some to support a wireless backhaul connection, but if you are using a wired backhaul connection, then you can actually have them barely overlap at all.
I'm going to attempt to visualize this by showing different distances between the satellite (S) and router [R]. The satellite's signal is represented by parentheses below, and the router's signal by square brackets.
This would be ideal for wireless backhaul - enough bubble overlap to support a highspeed backhaul:
( S [ ) R ]
With a wired backhaul, you can separate them further, but you'd have a "dead zone" right in the middle of the two:
( S------)--[------R ]
What you had in your setup probably looked more like this:
( [ S R ) ]
Any device located between the the router and satellite in this case has two very strong signals under the same SSID, possibly causing the device to bounce between the two signals, causing streaming to be stopped and restarted over and over. This is the reason for a minimum distance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Since you modem has a built in router, be sure to try one of the following if you get another Orbi system:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
@va3lim wrote:
I’ve disabled beamforming, MU-MIMO, fast roaming and move the RBR50 & RBS50 a bit further apart (20 ft), no luck, still getting bufferings when watching movies, live shows or recordings from TiVo and Plex app.
